- 型号:Camera IR Imager Ti 125
- 数量:1
- 制造商: 厦门兴锐达自动化设备有限公司
[5] 谷定燮,修木洪,戴敏,等.1000kV GIS变电所VFTO特性研究[J].高电压技术2007,33(11):27-32.
GUDingxie,XIU Muhong,DAI Mine al.Study on VFTO of 1000kV GIS Substation[J]. HighVoltage Engineering, 2007, 33(11):27-32.
[6] 郭天兴,徐杰,王璇,等.电容式电压互感器传递过电压的试验研究[J].电力电容器与无功补偿,2008,29(1):23-30.
GUOTianxing,XU Jie,WANG Xuan,et al.Testing investigation on transfer over voltage ofcapacitor voltage transformer[J].Power capacitor and reactive powerCopmensation,2008,29(1):23-30.
[7] 高景明,刘永贵,刘金亮,等.陡化前沿Marx发生器的设计与初步实验[J].强激光与离子束,2008,20(1):167-170.
GAOJangling, LIU Tongue, LIU Jingling, et al.Design and preliminary experimentalresults of wave erection Marx generator [J].High Power Laser and ParticleBeams, 2008, 20(1):167-170(in Chinese).
[8] 陈建.GIS中陡波前过电压特性及影响因素研究[D].华北电力大学硕士学位论文,2006.
CHENJian.Characteristic of very fast transient over voltages in GIS and analysis ofinfluencing factors [D].Master thesis of North China Electric Power University, 2006.
[9] 刘轩东,李登云,孙凤举,等.用于纳秒脉冲高压测量的同轴电容分压器[J].高压电器,2008,44(1):32-36.
LIUXuedong, LI Dengue, SUN Fungus, et alga coaxial capacitive voltage divider fornanosecond pulse measurement [J].High Voltage Apparatus 2008, 44(1):32-36(inChinese).
[10] 凌子恕.高压互感器技术手册[M].北京:中国电力出版社,2005.
[11] GB 20840.1-2010互感器第1部分:互感器通用技术要求.
GB20840.1-2010 Instrument transformers. Part 1: General requirements.
[12] 廖传书,黄道斌等.Lab VIEW与USB的直接数据通信[J].现代电子技术,2007,259(20):4-6.
LIAOChianti, HUANG Daubing, et al.Direct Data Communication between Lab VIEW and USB[J].Modern Electronic Technique,2007,259(20):4-6.
[13] 阚宝风,施乐平,马宪民.基于LABVIEW的冲击测量系统[J]仪器仪表学报,2010,31(8):352-353.
KanBaofeng,Shi Leping,Ma Xianmin.The shock measurement of data acquisition systembased on LABVIEW.[J].Chinese Journal of Scientific Instrument,2010,31(8):352-353.
[14] 张佩,赵书涛等.基于Lab VIEW的变压器直流电阻快速测量系统的设计[J].电工电气2013,7:42-45.
ZHANGPie, ZHAO Shoat, et al.Design of rapid Measurement System for Transformer DCResistance Based on Lab VIEW [J]. Janise Electrical Apparatus, 2013, 7:42-45.
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
Honeywell, 060-0240-05, Load Cell Model 53 30000lbs Sensotec 30k NEW
Sterlco M2B 250 Temperature Controller 601.00521.10 RS485 NEW
Rexroth, VT5004, Proportional Valve Amplifier Card Bosch NEW
Yaskawa Servo Motor SGM-02AW14D motoman ac servomotor
AC Tech SF230Y Variable Speed AC Motor Drive Lenze SCF VFD NEW
Fireye EP160 Programmer Module Non-Recycle 0123-38 NEW
Grundfos CHI4-30 A-W-G-BUBV Motor/Pump C 4J568003 P10002 NEW
Honeywell, UDC2000, DC200H-0-000-100000-0, Mini-Pro Temperature Controller NEW
Connect Tech, IAT04064, IAT04064MT, Intellicon 4 Port w/ Male DTE Cable NEW
Honeywell, M7284A1012, Modutrol IV Motor NEW
Parker, L6653921153, Solenoid Valve NEW
Hoffman C-SD362412 Concept Wall-Mount Enclosure w/ C-P3624 Panel 14.25x36x24 NEW
Vigo Drive HW9280784 Reduction Speed reducer Gear U-Axis UP6RS Motoman Robot NEW
Mitsubishi, HF-KP13, AC Servo Motor NEW
Allen Bradley, 1769-IF8, 8-Channel Analog Input Module Ser.A NEW
Unico, 313-240, PC Board 313-240.2 9513 Drive Repaired
Dynagard GfG Instrumentation Toxic Gas Monitor NEW
Siemens, 6ES7 322-1FL00-0AA0, Simatic S7 Output Module PLC NEW
Keyence, PJ-50A, Safety Light Curtain Emitter & Receiver NEW
GE, SB361RGRI, Bus Plug Spectra Series General Electric 30A 600V 3Ph NEW
Lambda, JWS300-24, Switching Power Supply 24V NEW
Allen Bradley, 22B-D4P0N104, PowerFlex 40 AC Drive Ser.A NEW
Giken GPC-P Power Supply ERB01A NEW
Crane IS-451-0020-AP Zemo Inline Torque Transducer Checkstar Angle 1/4 .25 aimco
Zoltman VED 20019BA-G28T Control board
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
工控宝APP下载安装
